Closed Sheet metal corner
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
I´ve now seached and tested a bit... how can I achieve the following closed corner?
Best regards,
Axel Kollmenter
Axel Kollmenter
Axel_Kollmenter
john_mcclary Aaah the last picture is perfect! ok now I can change the Jointstyle to the Butt joint. Thats how I wanted it. I allready tried the seperate feature, but somehow it doesnt work. Now its perfect! Thank you very much.Best regards,
Axel Kollmenter3
Here are some examples:
Then you can set the butt joints in the flattened sheet-metal tab
The picture I posted in my request is my goal (it is just a step file and I want to recreate it)
Best regards
Axel Kollmenter
Axel Kollmenter
