Closed Sheet metal corner
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I´ve now seached and tested a bit... how can I achieve the following closed corner?
Best regards,
Axel Kollmenter
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    john_mcclary  Aaah the last picture is perfect! ok now I can change the Jointstyle to the Butt joint. Thats how I wanted it.  I allready tried the seperate feature, but somehow it doesnt work. Now its perfect! Thank you very much.
    Best regards,
    Axel Kollmenter
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,065 PRO
    edited March 2022
    Your corner conditions are under "Relief" in the sheet-metal feature:
    Here are some examples:
    Then you can set the butt joints in the flattened sheet-metal tab
    edited March 2022
    Hi john_mcclary, thanks for your reply. But that´s not how I want it to do. My current part looks like the following picture. I have to close this corner gap so that it looks like the picture above.
    The picture I posted in my request is my goal (it is just a step file and I want to recreate it)
    Best regards
    Best regards,
    Axel Kollmenter
    Best regards,
    Axel Kollmenter
