No way to configure standard content?!
eric_pesty
Member, pcbaevp Posts: 2,550 PRO
Just found out today that standard content can't be configured, which seems like a glaring omission!
I just wanted to have to different length of bolt in a configured assembly but apparently I can't do it with Onshape standard content...
So I guess I can either create a fastener model that is configurable or just have to supress/resolve different sizes (but that also means multiple sets of mates), any other workaround worth considering?
Even if you could configure the length or material, there is still the bigger issue where you can't change the fastener type once set.
Since everything is mated with the Near/Far mate connectors. There should be no reason we couldn't configure between, hex head, button head, flat washer, lockwasher, Metric, ANSI.
I ended up making my own fasteners that are configurable in that way. So, I know it is possible with Onshape's powerful configuration tools.
If you would be flexible, not use standard, and made yourself , big lake of time
