Can I have more than 2 types of line within an OnShape Sketch?
Hello
In OnShape Sketches, is there any way to mark up individual lines other than:
A) Ordinary unbroken line
Dashed construction lines?
BACKGROUND
I am wrapping a complex shape with bookcloth (over card). I using an OnShape Sketch, from which I then create an OnShape Drawing (at life size), which I then export to PDF, which I then print at life size and use as a template.
I need to mark up:
1.The cut-lines for where bookcloth will be physically cut
2. The fold lines
3. The (rather complex) structures of the card underneath the bookcloth.
My problem is that each time I make changes to the Sketch itself, it updates whatever is in the Drawing...
Thanks!
J
BACKGROUND
I need to mark up:
2. The fold lines
Thanks!
J
Here is an improvement request you can vote on that may allow more line types: Line types
Meanwhile what workarounds exist?
e.g. Maybe each of my line types could be put into a separate OnShape Sketch?
But if I do so, how can I fuse these different Sketches back together again into a single drawing?
J
You can create multiple sketches of the different layers that you need, then create a drawing. While inside a drawing, sketches can be shown or hidden. You could have each sketch on its own page in the drawing.
If you share a link to your document, it will make it easier to explain for this specific case.
i.e. Is there an easy way to make sure that when import each of my Sketches into the same drawing that the end up exactly on top of each other?
AND for me to mark each different Sketch up in a different colour?
I forgot about that, I did color some curves in the past, however it looks like it's broken... Do you have any document currently showing colored curves?
I have one that used to show curves in different colors but they are showing up black now! Groups of curves used to be colored in this document!
Hmmm. Seems to be a regression. This was working for me, but the document where I had that working is no longer behaving.
I'll report it.
I've been told that supporting color for closed composite parts made up of curves was not intentional. Lou marked it as an improvement request. There was a bug recently, which got fixed, where they just disappeared if they were closed composites.
I also submitted a ticket and so Lou got at least two request for it today!
