How do I assemble this?
lynn_albritton
Member Posts: 5 ✭
Hi! Hopefully this is the right place for my question. If not, my apologies.
I'm trying to import an existing model of mine and put it back together here, thinking it would be a good learning experience and a test of OnShape's capabilities. I've watched several tutorials, but they are much simpler than my sample model. I have made a public document called "assemble me". Could I get some help on how to approach this?
I could have assembled this very quickly in several other CAD packages, which I'm afraid just makes me frustrated more easily. Is there a quick-start path for experienced/impatient CAD designers?
Thanks,
Lynn
Thanks,
Lynn
nav
Member Posts: 258 ✭✭✭✭
Hi @lynn_albritton I`tried to assemble your model and ran into some issues. I verified dimensions between the holes in the bezel ring and the base and there is a slight difference, this might be the reason you are having trouble with the assembly using Either Fastened or revolute mate.
For this assembly I`ll use mate connectors , its a bit different methodology from traditional CAD's but once you get the hang of it is way faster, not sure if you are very familiar with them, here some videos:
https://fast.wistia.net/embed/iframe/9v0dx21tqy?popover=true
https://fast.wistia.net/embed/iframe/j8cgok7zc6?popover=true
Nicolas Ariza V.
Indaer -- Aircraft Lifecycle Solutions6
This may not allow you to assemble correctly..
Onshape will create the most of needed mateconnectors for you automatically, it might be confusing in the beginning but when you get hold of it - you should save time while 1x mate connector = 3x traditional constraint
