FEATURE SCRIPT
myo_hlaing_winmyo_hlaing_win Member Posts: 9
how to write feature script (macro) for the construction of a fist washer (harmonic, tangential, Kurtz, Polydine)?
  • EvanReeseEvanReese Member, Mentor Posts: 2,409 ✭✭✭✭✭
    Hi, can you show images of what you're trying to achieve?
  • nicholas_radzykewycznicholas_radzykewycz Member Posts: 30 PRO
    If you would like help writing a featurescript I might be able to help however I don't know what it is you are asking for? Do you mean a washer like for a bolt with an inner and outer diameter or a washer like a pressure washer?
  • myo_hlaing_winmyo_hlaing_win Member Posts: 9
    Hello ,
    as a figure!
    @myo_hlaing_win
    This does look like a good candidate for featurescript, but I may not be the best one to help. I think it will mostly consist of creating a UI with inputs for all of the variables in these diagrams, and then plotting points using the dimensions above, then creating a sketch of the profile and extruding it with opExtrude(). Once you've got that working on the world origin, then I'd modify it to work on any plane you want.
    @Evan_Reese I am available to help with the featurescript and I have sent @myo_hlaing_win a message about it already. I haven't gotten a reply yet.
    If you have already ready, please sent me. i am waiting for you. And i am studying in on-shape feature script.
    Thanks You Very Much.
