Feature script for Tube
wayne_sauderwayne_sauder Member, csevp Posts: 605 PRO
Does anyone have a tool for tube routing? What I am trying to do is select points with various XYZ coordinates and the feature would make a straight run from point to point. Where the path passes through a point I need to be able to have precise control of a bend radius? This would be for a tube that is made on a standard tube bender. It seems all the workflows to do this are rather convoluted.
  • S1monS1mon Member Posts: 3,356 PRO
    edited April 2022
    There's this one which creates 3D sketches with fillets. You can then sweep along that. Not necessarily ideal.
    There's also this one, which has a slightly different workflow, and has some basic tube sweeping.
    It sounds like a custom FeatureScript would be helpful, especially if you want to model any of the distortion that happens on a tube bender.
  • wayne_sauderwayne_sauder Member, csevp Posts: 605 PRO
    @eric_pesty
    @S1mon
     Thanks, fellows, I actually had all these tools already, was just suffering from a mental block on getting what I wanted.  :#
     Your suggestions got the creativity going again. I do think that this could be a good candidate for a single feature script to do everything in one step??? Let me know if anyone writes such a tool.
  • EvanReeseEvanReese Member, Mentor Posts: 2,437 ✭✭✭✭✭
    I've been wanting to "heavily reference" (steal) the code from Illya's Ortho Lines script to add the functionality to the Polyline mode of Freeform Spline, but haven't gotten around to it. I also plan on making a Profile Sweeper feature that would make it easy to sweep a round profile without needing to set up a plane, sketch, pick each edge etc. I want to take the opportunity to make a Featurescript tutorial out of it too, which will probably slow down the release of that feature though. Once both of those are done I think they'd be perfect for a workflow like you're describing.
    It's not exactly related, but I've often thought that it would be great to create a FeatureScript which does something like Alias's tubular offset (creates edges which are some radius from the current edge of a surface (or other edge/curve reference). This is effectively sweeping a circle along an edge/curve, and then creating the intersection(s).
    @Evan_Reese
    Sound great keep me posted!!!
