Help With Flatten Sheetmetal
I Know this isn't 100% Onshape related but I have drawn a thin extrude item in Onshape and tried to flatten it in Solidworks.
I have no experience with sheet metal in Solidworks and its just coming up with an error and wont flatten unless I suppress 2 of the curves
Is anyone able to look at my model and possibly point me in the correct direction?
Its just one part in my workspace and don't want to make the whole workspace public yet but if anyone would like to help out I can share the file to you.
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
I'm dropping them in my Onshape file, can't be bothered with the Onshape sketch of bend details so just exported from SW's. I have fixed the problem with the end and set the k factor to .47. You can download/copy tabs from here: https://cad.onshape.com/documents/bf58ad03c2e348bd832182db/w/667d45b4a0ef418eaa0ae436/e/3420ec88a93c4ba3a53b6be4
5
If you post a link to your Onshape or a picture part can give more help
You could perhaps use "Copy workspace.." from the Document (hamburger) menu at top left to create a new document, delete anything in the model you want to keep under your hat, then share what's left.
thanks for the tip, I just figgered out how to copy it and can be found here: https://cad.onshape.com/documents/63f17fc0fd0543ef8cc77d85/w/838a24c31b7f46568f3bcc88
I can imagine Solidworks might have different levels of what sheetmetal it can flatten, depending on whether it was modelled in Solidworks as a sheetmetal part, vs imported from another package.
Which two bends have you had to suppress to get it to flatten?
I had trouble with double bend across the 2 bits with the 2 holes. I cut one side of each of the double bends out and added back in after flattening, not ideal but gets a result.
What do you want to achieve with this part on Onshape if you have Solidworks?
You could cut some ref notch's in to build a sketch from after import to Onshape then re export the sketch as a .dxf but why not do it straight from SW?
It also looked easy to import and flatten in solidworks till i ran into this problem.
I just need to flatten it and turn it to DXF to send to the local cut and fold shop.
