receiving error message when extruding and I don't understand what it is trying to tell me,
receiving error message when extruding and I don't understand what it is trying to tell me, in other words, I can't figure out what needs changing to fix the issue.
The error message is "Boolean operation failed to return a part". when I extrude as new, the new part creates successfully. when I try to add the new part to an existing part, that's when I get the error message. I've checked for interference when creating two parts and there are none. The two parts share a common plane/face. Also the screenshot shows one surface as being red, and I don't know why it is color coded red.
Thanks
Thanks
MichaelPascoe Member Posts: 2,447 PRO
This can happen when a vertex is being shared by several faces. Try overlapping the parts, or make sure there are no shared vertices:
If it is still broken and you can't get it to work, you can share a link do your document and we can troubleshoot it with you.
https://cad.onshape.com/documents/b4fe21b832ecc3ba8a8ae266/w/1cce0e794147413d5c6af952/e/9eb41c6cd739ab8b19bd
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1 -
NeilCooke Moderator, Onshape Employees Posts: 5,875
Probably non-manifold https://forum.onshape.com/discussion/comment/66817#Comment_66817
Senior Director, Technical Services, EMEA0
