Defect? - Points not snapping between different sketches.
karl_mochelkarl_mochel Member Posts: 38 ✭✭
II created a Sketch with construction lines that I want to use to build different spline loft segments. I am trying to snap spline points to the construction points but they don't seem to snap - though when I move the cursor over the points they do highlight. Is this expected behavior?
It's not preferred.
    dirk_van_der_vaartdirk_van_der_vaart Member Posts: 543 ✭✭✭
    Select the points you want to use, then hit the USE command.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,422
    Or just add a coincident constraint.
    Not a great solution but this is the more "use"ful suggestion because I can get what I need done, but it sucks as a solution because:
    1) You cannot fence select all the elements you want. You have Shift select them.
    2) Depending on how you select it doesn't translate the line type. If you select a midpoint instead of on line the entities comes across as sketch entities. So you need to change them back.
    Doesn't work for this situation. Am doing inference constraints so I don't actually want to snap to those points. I am inferencing them to create vertical, perpendicular, or other constraints.
    OK, so add a vertical, perpendicular or other constraint.
