Defect? - Points not snapping between different sketches.
karl_mochel
Member Posts: 56 ✭✭
in Drawings
II created a Sketch with construction lines that I want to use to build different spline loft segments. I am trying to snap spline points to the construction points but they don't seem to snap - though when I move the cursor over the points they do highlight. Is this expected behavior?
It's not preferred.
It's not preferred.
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
Select the points you want to use, then hit the USE command.0
1) You cannot fence select all the elements you want. You have Shift select them.
2) Depending on how you select it doesn't translate the line type. If you select a midpoint instead of on line the entities comes across as sketch entities. So you need to change them back.
