Can more than 1 import be put into the same part studio? If so, how is this done?
alwyn_limalwyn_lim Member Posts: 57 ✭✭
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Hi @alwyn_lim - use the Derived feature to bring in as many imports (or other models) as you like.
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    I've wondered the same thing before and your post got me curious so I did some digging, and found that there's an FS function for it so I wrote a feature for it between meetings. It's a lot faster than deriving the same thing. too. https://cad.onshape.com/documents/61cc8612f166ab2d49db4e3a/v/bb7dda147bbbebd5f32f5df9/e/3230f795252a09ff6486a466
  • MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
    @Evan_Reese
    Another feature
    Me:
    @MichaelPascoe
    lol. I literally just went "show code" on a studio that had an import, to see what function was used, then made a wrapper for it with FS. It's almost no code at all:
    FeatureScript 1746;
    import(path : "onshape/std/geometry.fs", version : "1746.0");
    annotation { "Feature Type Name" : "Import 3D File" }
    export const importFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "3D File" }
            definition.file is CADImportData;
            opImportForeign(context, id + "importForeign1", {
                    "blobData" : definition.file
  • alwyn_limalwyn_lim Member Posts: 57 ✭✭
    @Evan_Reese Wow, thanks! ..... Added your custom feature into my toolbar and was able to insert multiple pre-imported 3D into a part studio.
    Was wondering whether it's possible use your custom feature to directly select a 3D (eg STP,/STL on my local hard drive) that has yet to be uploaded to Onshape (ie already in another part studio)?....... Hope this becomes standard in Onshape soon.
    I don't think there's a way right now. I know that when adding an image or dxf to a sketch there's a button at the bottom that does that (see screenshot), but I don't think it's possible for me to add it with FeatureScript. I'd love to be wrong though. Anybody know a way?
    @Evan_Reese Could you please add an option to directly position the imports (without having to do subsequent Transforms) in a Part Studio (eg: placed at a Mate Connector where the import part Origin is)?
    Use case: when trying to superimpose parts, but scan file Origin is different from externally modelled 3D file Origin..... Have just posted an improvement request on this too, but no telling if and how long this will take to be built into OS.
    I can, but I suppose I don't see the value. All I can think to do it essentially add the "Transform by mate connector" UI to this feature, but that Transform feature is a click away, so why bother? I try to avoid clumping features together that could be easily created by a chain of features, which is what CAD is all about. Is there a use-case you have in mind that this is a pain for?
    @Evan_Reese you are right; it's just 1 more feature..... just thought it's cleaner to import directly into the correct position.
    Got it. That makes total sense. I often made the mistake early in my FeatureScripting of trying to pack too much into a single feature, and have been trying to simplify a bit. Keeping unrelated functionality in separate features actually makes them more widely applicable since they can be combined in more ways. That's my take on it anyway.
