How can I make two remove extrudes that overlap
melodie_glassermelodie_glasser Member Posts: 3 EDU
Hi, I'm very new to 3D design, so I'm probably going about this the wrong way, but how can I have two overlapping remove extrudes that lead to a connected region?
In this cylinder, I want to have two tunnels that lead to the center.  In the center, I want them to join with a recessed region, that does not go all the way through this main cylinder, however, when these removals overlap, there's an error.
https://cad.onshape.com/documents/55f382d0617a3378766cbb63/w/cdfa49ae5deb43f17c5e008b/e/f1d973ff2c2325828f65f509?renderMode=0&uiState=627c1b65457b57023032418f
Thanks!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 933 PRO
    I believe the extrude that is failing is creating zero thickness geometry because the circle you're extruding is tangent to the tunnel end.  One fix would be to reorder the features to have the central recess first and then make the tunnels "Up to surface" rather than "Blind."
  • melodie_glassermelodie_glasser Member Posts: 3 EDU
    Awesome, thank you!
