flange creation
allen_schultz135
Member Posts: 19 ✭
I am struggling to make a flange(s) on this 3mm plate. Part studio will not accept an edge to drop a 76mm flange.
Please show me the way. Thx, Allen.
Website: ovyl.io
You are creating interfering geometry. You will need to make some modifications to some of the flanges in order to get it to work.
https://cad.onshape.com/documents/7c2d8d3fdff975230885f707/w/875768aacbf4d697c00cc964/e/d2c567f3fde8a85bcf8de13e
You make a valid point. Contact support or write an improvement request for us to upvote.
that is the top of a step in 3mm MGP, need a 20mm down flange at rear, a 30mm flange down front & 2/ 76mm flanges down thw sides.
thx. Allen.
13:22 5/13/22
I thickened the plate. thx. Allen.
Last week I did get this project created, even managed to export a DXF ready for a Laser Cut machine. I needed to reduce the overall width by 16mm, so tried to do this by altering the dimension in the very first / top sketch, understanding that this is the way to go, Yes, it worked but immediately caused a whole bunch of RED flags (text) of "not acceptable" inputs.
So, I scrapped the whole project. Then started again. Then hit the brick wall.
Thx, Allen.
https://cad.onshape.com/documents/874d21e66b053a1d2b042945/w/5a0d2ed92ae5b5fc66904c49/e/86690281f97cfb14999a66a6
