Is there a way to remove all face colors from a part?
mark_wills490mark_wills490 Member Posts: 5 ✭✭
Is there a way to remove all face colors from a part? I looked in help and did not find a way
    mahirmahir Member, Developers Posts: 1,291 ✭✭✭✭✭
    Open the Appearance panel on the right. Any face appearances will appear under each part. You can then select them all and suppress or delete.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,415
