Blank parts in sketches
bartbart Member Posts: 19
When I want to make a blank part in a sketch (let's say I want to draw a washer—a solid circle with a smaller blank concentric circle) it sometimes just makes the part I want blank solid. It appears to decide at random whether or not I deserve a blank area in my sketch. I usually just leave it to chance and work around it but there must be a way. Anyone know?
Many thanks,
Bart
    @bart
    Check out the training videos on sketching, they explain this issue well
  • bartbart Member Posts: 19
    Thanks! I must have forgotten.
    @bart , you can select or deselect solid circle or blank concentric circle (required portion) of sketch for extrude from model space window as shown below video.
    Hi Viru,
    Thanks! I think I already knew this but I haven't used Onshape for a while so perhaps I was just frustrated.
    Thanks for your help :smiley:
    Bart
    At some point it was filed as a bug when you select whole sketch to extrusion and sketch holds 'washer type' -geometry which you would expect to extrude as a washer rather than only outer circle.
    A washer *is* only the outer circle... Do you mean the whole thing would extrude?
    edited August 2015
    I think bart and 3dcad are both taking (different) liberties with the word "circle"
    In the exacting language of geometry, as used in solid modelling, a circle is a single, infinitely thin line.
    Extruding a circle would produce a surface, not a solid body.
    I think 3dcad meant the area bounded by the outer circle only, in other words, something which would extrude as a disk rather than an annulus.
    @andrew_troup Thanks (again) for understanding my point and explaining it with better terminology.
