Rendering errors in Safari 15.4 Mac OS 12.3.1 M1 Processor
Wolfram
Member Posts: 4 PRO
I am seeing rendering issues where the the part appears to "jump" when the mouse moves over it and selection choices are highlighted. It is like the background image being shown is an earlier one, but the orange selection choices are in the right place.
It would be really nice if Onshape was testing regularly in the current version of Safari on current Macs. It seems like this is an afterthought all the time.
Part of why I'm happy to use Onshape is to be able to avoid Windows. When things don't work on Macs, it starts to feel like Onshape doesn't care. I can see from various demos and other videos from Onshape that a lot of the team is using Macs. Please prioritize Safari, and check on M1 machines!
What I'm seeing now is that the occlusion shadows are taking a while to redraw. I spin a model and the frame rate of spinning is very good, but when I stop, there's about a 1 second lag and then the shadows are drawn. When I hover over the model, the surfaces pre-highlight, and the shadows are turned off, and then if I mouse off, or select something, then the shadows are redrawn, again, with about a 1 second lag for the model I'm using.
The behavior is distracting enough that it's still much better for me to use Chrome for Onshape and Safari for everything else.
In previous versions of Safari/Onshape this redrawing was much more distracting and was flashing/offset in weird ways.
