The Circular Pattern is popping up and not pooping up at times.
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I am having problems with the circular Pattern sometimes it pops up at other times it doesn't. I am trying to generate that box 30 degrees around 11 extra copies.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 903 PRO
    I don't think I have ever noticed the circular pattern popping up ever (or pooping :) ).  What do you mean by popping up?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,981 PRO
    I assume you mean: The icon on the toolbar isn't always there.
    If so, then the answer to that is:
    The patterns are grouped together under the same button.
    It always remembers the last pattern you used and keeps it up-top.
    To access the other patterns click the down arrow to see the other pattern types.
    alternatively.
    If you can't find a feature, just press alt+c then type the name of the feature you're looking for.
    It will automatically search every feature available to you, including customer features.
