BULK DRAWING TEMPLATE UPDATE
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,144 PRO
Is there any way to do a bulk drawing template update?  I had a full set of drawings done using the wrong template and now have to update each one.   I'd love to be able to group select and update or use some form of automation.
    I wish, but even worse than that. When you create a new drawing sheet in that tab. It will still use the original drawing template. Which makes it even more upsetting.
  • JPMJPM Member, csevp Posts: 16 ✭✭
    Any chance there's a way to do this Now?
  • armandoRRarmandoRR Member Posts: 18 PRO
    From support this week:
    "There is not a way at the moment. We ultimately need a block library that references versions and the drawing templates to be comprised of block elements that can be updated and then the drawings know which blocks need to be updated from the block library."
    There is an improvement request here:
    https://forum.onshape.com/discussion/21450/bulk-batch-drawing-template-updates
