How to fill solid of the inside suction cup's bellow?
ismat_jahanismat_jahan Member Posts: 25
Hello,
I am trying make inside solid-mold of the suction cup's bellow part like the reference. For this I need to fill up the inside of the bellow to get the solid inside-curves.
My plan is after getting the inside curve solid model, 3D print it & use it inside of the silicone mold. I just can't fill the hole accurately to get the inside's solid curves.
How do I do it? Suggestion please, I am struggling on this...
  • eric_pestyeric_pesty Member Posts: 2,309 PRO
    I think the "enclose" feature should work for this...
    Or you might have to do a "zero offset" surface out of the external faces and cap the open end(s) with the "fill" feature
  • EvanReeseEvanReese Member, Mentor Posts: 2,516 PRO
    edited May 2022
    One lazy way would be to just model a new block around the bellows, perform a boolean subtract, and then delete the external body to leave the internal volume. It's not necessary the most elegant method, but it requires few selections and is robust to changing geometry. The block would just need to have the same flat top and bottom surfaces as the bellows.
    https://cad.onshape.com/documents/9274ff6f8d6ef85343d41bc3/w/1e2f935958fd3d24ad19de38/e/debefeb8fb0d2e985eb8bee2
  • S1monS1mon Member Posts: 3,494 PRO
    edited May 2022
    Another quick way:
    Create top and bottom surfaces with Fill (just pick the circular edge). Then Enclose (pick the fill surfaces and the bellows). Then you can Boolean Union. This doesn't require any sketches, and the selections are very simple.
  • ismat_jahanismat_jahan Member Posts: 25
    I did the zero offset of the external surface but I can't fill with solid by capping the open ends
    The fill can only do one opening at a time, you just need to use 2 separate fill features.
    This is the exact kind of thing I wrote that Cap feature for. It just finds open edge loops and does a fill with positional continuity. Nothing groundbreaking but it's convenient.
    S1mon said:
    Another quick way:
    It's the most easiest way I found! worked like magic! THANK U.
    Yes, the cap feature is new to me! from u I learned this method. Appreciated.
    Got it!
    S1mon said:
    Another quick way:
       Thanks a LOT!!!! <3 I'm overwhelmed with joy! <3<3
    Thanks a LOT!!!! 3 I'm overwhelmed with joy! 33
