How to fill solid of the inside suction cup's bellow?
ismat_jahan
Member Posts: 25 ✭
in General
Hello,
I am trying make inside solid-mold of the suction cup's bellow part like the reference. For this I need to fill up the inside of the bellow to get the solid inside-curves.
My plan is after getting the inside curve solid model, 3D print it & use it inside of the silicone mold. I just can't fill the hole accurately to get the inside's solid curves.
How do I do it? Suggestion please, I am struggling on this...
Also attaching the Onshape document I am working on https://cad.onshape.com/documents/dbca8efe127f123f23de7f2e/w/ab863033ff5c445898d1b3dc/e/5f07cb0ab04fc4577eb1947a?renderMode=0&uiState=6290ec095abc44465af34b23
Or you might have to do a "zero offset" surface out of the external faces and cap the open end(s) with the "fill" feature
https://cad.onshape.com/documents/9274ff6f8d6ef85343d41bc3/w/1e2f935958fd3d24ad19de38/e/debefeb8fb0d2e985eb8bee2
Create top and bottom surfaces with Fill (just pick the circular edge). Then Enclose (pick the fill surfaces and the bellows). Then you can Boolean Union. This doesn't require any sketches, and the selections are very simple.
It's the most easiest way I found! worked like magic! THANK U.
Yes, the cap feature is new to me! from u I learned this method. Appreciated.
Got it!
