Alternative to lots of hidden feature params?
EvanReese
Member, Mentor Posts: 2,763 PRO
I'm doing a lot of UI logic that changes based on user selections. I'm doing it by using hidden boolean parameters and toggling them with editing logic. For example, the UI might look different depending on whether someone picks a vertex, edge, non-planar face, planar face, or nothing. My issue, is that there are getting to be quite a few of booleans. I also have some hidden integers for point indexes. I'd really love to be able to just have one hidden parameter that's a map of all of my booleans, then address it in the UI. I'd fill it with something like
{"pointIndex" : 1, "noSelection" : false, "isVertex" : false, "isEdge" : true, "isFace" : false, "isPlanarFace" : false}
Is there a way to do something like that? I can get by without it, but it just gets clickity-clackity to write, and fluffs up the code making it harder to read.
NeilCooke
Moderator, Onshape Employees Posts: 5,952
You have to remember that the UI is a predicate so it cannot react to any logic created in the body of the script (apart from Editing Logic).Senior Director, Technical Services, EMEA0 -
kevin_o_toole_1
Onshape Employees, Developers, HDM Posts: 565
Yes, in order to get conditional visibility you need the booleans listed out explicitly. Our UI only has logic for dealing with those explicitly listed parameters. It sounds like you've made the simplest functional solution.Evan_Reese said:if (definition.UI.boolean1)
*Other parameters to show*
}0
Functionally, I don't think it would really differ too much from having a hidden parameter map as you are suggesting,
as in both cases you still need to have an if statement checking a map variable.
If your biggest gripe is a messy precondition, moving it away into a precondition would at least organize things.
then in my precondition something like
I struggle with code formatting on the forums but here's an example script
https://cad.onshape.com/documents/74b868c81ffd51b8b4a9c6a5/w/facc72e9362395db8a26dc6b/e/3cbb4cc8c851cbb31b6aa7b0
