Hobbyist looking for advice on building difficult structures
in Drawings
I am a hobbyist and I have been using Onshape for about a year. Loving it and after using Freecad, it is so much more elegant.
Anyway, I am looking for advice, that might be more suitable to a maker's forum, but I thought I'd try here in case there is some funky feature in Onshape to help me directly.
I have drawn a drain leaf strainter. The drawing is here. https://cad.onshape.com/documents/d1c2ce417c4a1ce1929a6f6b/w/3f729b7dc92ed16468f6dc0c/e/2ab2252e7de05181874d4beb?renderMode=0&uiState=62a028878bfb3069d20c7fbf
The problem I have is that when I 3D print this, the fingers are very unstable and move around with the printhead, so the quality is pretty awful. What I would like to do is draw a very thin cylinder inside the structure with small contact points every 10mm or so to stabilise the entire model as it is printed. Is there a trick to doing something like this in Onshape, or do I have to manually create this as part of the drawing?
Cheers
Cheers
This?
Yes I thought of that and it would improve, but not totally fix the issue as the bars start to move at a reasonably short length. I am going to put a thin cylinder inside the main frame and then put small connectors to the bars every centimetre or so. When it is printed, I will break away the internal cylinder and cut the small nipples from the bars. This should make it a rigid structure to print.
1. Have you tried turning on z-hop in the slicer? Cura has this setting. This lifts the print head between contiguous extrusions so that it doesn't snag on the print.
2. Make ribs going up the outside of the walls as reinforcement (or just make the walls thicker).
I think, combined with Dirk's solution, this should let you print the part fine.
