Renderstudio Perspective
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Hello @mfalkensteiner , Hello everyone,
last thursday you introduced the OS RenderStudio in the german user group meeting.
I have a question regarding the saved views. We have always used the same view to display products in the catalog. Now we want to recreate the exact perspective in Onshape Renderstudio. Is there any way we can get the exact perspective rendered? Can we load an image of the current view into Renderstudio, adjust the assembly to it, and then save the view?
Is this possible, or does the view have to be averaged out by eye?
I know how to save a perspective, the point is to determine the exact perspective as before.
Best regards,
Axel Kollmenter
Axel Kollmenter
Currently it's not possible, the closest that can be done atm is using the default view cube positions.
It's a requested feature and currently being worked on.
Axel Kollmenter
Axel Kollmenter
In the Assembly you can't control the field of view however once in Render Studio you can adjust it to a different value if needed.
Axel Kollmenter
I'm hoping this is why this is still a Beta and not a 1.0 release. I assume that the fact that it's so different and not more smoothly integrated is not lost on Onshape.
Honestly, if the integration is not much better, then the biggest reason to use it over third party solutions could be cost (if it's "free" - included with plans), but I also assume this might be an upcharge on top of existing Onshape plans.
The speed seems pretty good, but the UI and UX are pretty much a dump of a lot of parameters into tables. There's little attempt to make the units correspond to things which make sense as a user. I've seen other rendering systems which make much more of an attempt to use physics based approach where things like the scale of texture is based in actual model units (e.g. pixels/mm) or the brightness of a light is in lumens, etc.
We are definitely looking for input on what needs to be improved and how we can make Render Studio better.
I would like to share a bit of background. Remember that Render Studio started off as an independent, 3rd party app. It was integrated with Onshape with its own unique UI and user experience.
Once Migenius became part of Onshape. The goal was to make Render Studio more in line with the way Onshape does things. UI, versioning, etc... There are some pieces of this that can be done quickly and others that require a bit more development. We were faced with a decision, do we wait until it is all done? Or is the existing UI and workflow valuable to our users now? We thought the right thing to do is to make it available, while it continues to evolve.
I think you will be happy with what the team is working on. And yes this is one reason there is a beta label.
Aside from matching positions between scenes we also had some users want to use type in values for example to level out the camera exactly or do other things where they know the location needed, so it will serve two purposes there and even if deeper view management and sharing is added later it will still be useful to have.
Axel Kollmenter
Yes I am grateful Onshape has done what was needed to at least allow people to use it right away. As I was saying, I do actually love the renderings them selves and the level of control over everything. Will be nice when the new view options come out. I get you guys have a solid process for evaluating what exactly is going to be worked on next but sometimes, for me anyway, it is hard to comprehend the decisions. For instance, positioning a sticker texture. Probably the most simple thing to do anywhere including in the real world. About the hardest thing to achieve in render studio. Every parameter is dependent on the other so it is at least 3 to 5 mins just to put a stick in the right spot. I'm using render studio now as my main rendering source (visualize standard will expire soon) but honestly, I can download, import, apply all appearances and decals before render studio finishes translating the same model. Anyway, not trying to distract from the main topic of discussion here.
