Selecting named positions in drawings.
YWC_Brencis
Member Posts: 15 PRO
Does this functionality not actually work in drawings?
I've searched around the forums and it seems that it doesn't.
I have an assembly that has Named positions. Whenever I select a different position in the assembly and update the drawing, all of the views show the selected named position, so I can conclude that information about it has reached the drawing. However, I need different named positions for different views. The named positions I have in the assembly do not show up in the Explode/Position drop-down menu.
2
PeteYodis
Moderator, Onshape Employees Posts: 564
@3d.2 I've created a ticket for you and placed you on the improvement needed.
We need to do more work to translate assembly named positions into what is needed for drawing views. The workaround for now is to make your named position active and then start an explode from it without adding any explode steps. Then reference that explode view in your drawing.
2
