Does enyone else had/have this problem?
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
in General
It happens not always but very often... this is so annoying.... I don´t know where the problem is....
-Google Chrome-
Best regards,
Axel Kollmenter
Axel Kollmenter
But you can press ctrl+w to close the tab rather than clicking on the x
Axel Kollmenter
RENDERCAD
Are you using a 3dconnexion 3d mouse (perhaps with a usb hub)?
Axel Kollmenter
Ok. That will be the cause of your problems then.
I had a setup like that, so here are some observations:
Plugging both devices directly into the computer rather than through a hub seems to help a little bit, but the problem is still there.
The only way I've found to make it stop is to unplug either one of my 3DConnexion devices (mouse or 3D mouse). However, the implications of that are painfully obvious.
Do you have a CadMouse Pro Wireless as well, because having two 3DConnexion devices seems to be key
Axel Kollmenter
Ok. I got it in Edge, but couldn't in Chrome. It only ever seems to do it when I aren't trying to look for it.
Of note could be the fact that 3DConnexion has inbuilt commands (such as refresh, next tab, print, bookmark, etc.) for Edge and (I think) Chrome.
Axel Kollmenter
But it's nice if you've found a solution for yourself with Firefox.
These days it's been much more stable with Chrome. Maybe once every couple weeks it dies and I have to restart the 3DxNLServer.app or even reboot my machine.
"Just use a regular mouse and keyboard."
To each, their own, but no thanks. Holding down the middle mouse button while dragging to spin is a recipe for carpal tunnel syndrome. For me, a 3D mouse is the difference between being able to do CAD comfortably for many hours a day and being in serious pain, wondering if I'm going to need an operation.
The spin center can get wonky sometimes, but usually if you stop spinning for a fraction of a second and get your pan/zoom back under control the algorithm will behave and find the spin center correctly. It can also be thrown off by sketches, planes or origins which are way away from the center of the part(s). If you hide these then zoom to fit and rotation will generally be under control.
You can optionally show the spin center so that you can see what it's doing. I leave it off, but in the past I had it on.
I've also always used 3D mice with the in/out (zoom) and up/down controls swapped. The defaults never made sense to me since they effectively rotate the coordinate system from the mouse hand (left/right, up/down are all in the plane of your desk).
I also had to swap things when I was trying out the 3d mouse thing.
They are ok. But their drivers are terrible. Their software ends up breaking other programs (such as video games that rely on a controller or joystick). Or they just reset their settings at random.
I ended up throwing them both in the server closet since they cause more harm than good.
The drivers leave a lot to be desired. Things have gotten to a point where it's stable again for my setup, but I was going through some hell for a while.
To some extent, settings randomly changing thing seems a bit like a Windows issue. There are several preferences in Solidworks which would randomly change that I would have to carefully check. I'm not having those same issues on my Mac, FWIW.
Menu options come and go... Man, I hate SW...
Axel Kollmenter
