Big problems editing a sketch
john_smith077
Member Posts: 175 ✭✭✭
Hello
I have got myself into a bit of trouble editing a Sketch.
My Sketch consists of two quite complex areas (call it "Area_A" and "Area_B".) that are connected by a simple pair of lines.
The problem is that my pair of lines was originally created [in error!] using a Mirror, and now I need to lengthen this pair of lines. In this way I am hoping to move Area_A and Area_B further apart. [If not I will have to do hours of work!]
FWIW, the history was that first I created "Area_A" and then I created "Area_B".
i.e. I worked from right to
The strange the is that if I delete the two lines that connect Area_A and Area_B, much of Area_B stays black.
i.e. It is properly anchored and so it can't be moved.
But I have now idea how come the whole of Area_B doesn't go blue!
Any suggestions? (I really, really don't want to rebuild Area_B from scratch)
Cheers
J
PS I am still quite new!
Cheers
J
Post the URL
EDIT
OK try this:
https://cad.onshape.com/documents/de034e825102d66adecc250b/w/0b31a58dee9a7f5e1c3b375e/e/c2754ce7c63d3b14534858f8?renderMode=0&uiState=62aa57e259d2e2753a799acc
Thanks
J
I am using a rubber hinge which is quite hard to model accurately.
If I create this book-cloth part it in multiple separate Sketches, presumably OnShape will create multiple separate Parts, each of which I would then need to bond together. :^(
J
But the wrapping is quite complicated because:
A. In many places it needs to overlap over itself. [Can OnShape's sheet metal tools do that?]
B. It needs holes punched through it
C. It goes over 45 deg chamfers
D. If goes over a soft rubber hinge (that is already slightly hard to model!)
(E. Fwiw, I am hoping to print the Sketch on an A3 printer, and it would help with assembly to have the construction lines that I have drawn...)
And finally, because I am new and my small brain can only handle a limited amount of new information at once!
J
That tool is for any material that you want to fold/flatten.
-cardboard
-paper
-etc.
Sheet-metal is just the typical use for that modeling suite, so it inherited the name 'sheet-metal'.
As per @wayne_sauder you can use TRANSFORM within the Sketch
I shall investigate the Sheet-metal thing next time/when I have time.
Cheers
J
If you're extruding a part, for example, you can do Extrude1 using sketch 1, then Extrude 2 (selecting the "Add" tab in the dialog box) using Sketch 2. If the two extrudes are touching, they'll automatically be combined into a single part.
And given how hard it is within OnShape to see why any given line is blue, this is an utter nightmare.
Why can't Onshape just leave in place ALL of the relationships between lines within the area being "Tranformed"?
OnShape is brilliant in many ways, but editing Sketches is a major weakness.
This is extremely disappointing.
From this point, you can set some variables and make it parametric, but the concept is there
TEST001 (Document) - Copy | Part Studio 1 (onshape.com)
the only 'sketch' in the whole part was a simple square
