When Editing, is it possible to break a line in two?
john_smith077john_smith077 Member Posts: 175 ✭✭✭
Hello
Background
The problem is that if I delete a line and re-build it, all the various dependencies based on the original line break and everything turns blue!
Thanks
J
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    Yea, it is the split tool
    mahirmahir Member, Developers Posts: 1,291 ✭✭✭✭✭
    I use the split tool for this as well. But keep in mind the constraints won't necessarily be propagated the way you intend, and you will probably have to redo some of the them.
    ShapenShapen Member Posts: 13 ✭✭
    I would recommend taking a look through the learning center. https://learn.onshape.com/
    There are wonderful self paced courses and technical briefings. For example, there is a course on sketching that covers the split tool you are looking for. https://learn.onshape.com/learn/course/fundamentals-sketching/sketch-tools/extend-split?page=1
    Axel_KollmenterAxel_Kollmenter Member Posts: 410 PRO
    edited June 2022
    You can use the split tool like @john_mcclary said, or you can place two dots on your line and cut away the middle part.
    The results are the same but with the "dot-method" you have two dots you may have to delete.
    This is a workaround I used to do in SolidWorks.
    Best regards,
    Axel Kollmenter
