Best format to import an OnShape drawing into Microsoft Word?
john_smith077
Member Posts: 175 ✭✭✭
Hello
What is the best format for importing an OnShape drawing into Microsoft Word?
My drawing have both dimensions and Shaded View switched on.
I need to automatically trim off as much 'white space' as possible.
e.g. Should I use:
- a general purpose vector graphics format (like .PDF or .SVG )
- a CAD drawing format (like .DXF or .DWG)
- Or just create a high resolution pixel/bitmap (like .JPG or .GIF)
Background
I need both general management & marketing staff and also production managers to be able to see the drawings in high resolution.
Thanks
J
PS EDIT:
It doesn't seem to be possible to import .PDF files into a Word document, but is there any reason not to use .SVG? It seems to work well, but I have never used it before... What would be industry standard practice?
e.g. Should I use:
Background
Thanks
J
PS EDIT:
In my experience you have to say what the paper size is (e.g. A4 or A2 or whatever) when you create the OnShape Drawing, no?
I think PNG is a bitmap (or should I say "raster graphic"?) where the data is held in a 2D matrix of square pixels, because then you have to start to think about resolution and file size.
Why not let them have OnShape accounts?
Not for now, because I things need to be kept as absolutely simple as possible, but yes, potentially a nice idea at some future point.
J
I use edge, I don't know if the others have something like this or not but it allows you to select and scroll in one move for items larger than your screen...
-I'd use a jpg as it's smaller than png.
-John that's the coolest screen capture I've seen, but, it's still a jpg or png depending on how you've set your capture buffer.
-I'd never add a cloud link to a word document. I would make that assignment in a google doc. I'm not a hybrid cloud fanboy.
-Keep image resolution reasonable, remember that a doc with "hello world" and a 1 gig image is still a 1 gig document.
Even with a public document, you have to have an onshape account. The reason isn't to make money but to log who did what and when. I'm certain that light accounts will have to have known users. It's scary to have a server and just open it up and let all traffic through.
Me, I'd just cut'n paste the image, my capture program (osx) is set to jpg.
Remember the cut'n paste buffer has to be compatible as a system, for those who have setup a buffer in the vi editor it's not that easy. Windows is a fairly complete system for this operation. Google docs is more fickle but it's doing more and gives you a better cloud presence in the end.
If I wanted updating images, I'd setup a proxy server and have onshape fire off webhooks to update assets. I think this might be the best way to create updating cloud assets without any authentication. In this case, if your proxy server gets hijacked, then it doesn't bring everyone down with it.
JPG will be smaller than a PNG with certain types of source material (e.g. photographic images of natural things), but PNG is likely smaller for a drawing than JPG, and it is lossless. (there are newer special flavors of JPG that are lossless, but they are not as universal.)
All that said, I would try hard to move towards something which is vector based (PDF at least) and ideally is connected to the CAD system. I also live in the real world and know that some consumers of CAD info can't deal with things that aren't in formats that they are very comfortable with.
https://cad.onshape.com/documents/de16ce75f8b64724c749f2e8/w/b57326453544854705356e76/e/34d8c9d7bd055c1b61ad0f37
TBH, I've never used that format before but it has the advantage of not only:
A) Precisely controlling what the third party will see
This can be important for initial meetings with 3rd parties - particularly where internet connectivity is not a given.
PDFs have the problem of being having a pre-defined paper-size. From what I can see this make it impossible to insert into a msWord document & resize accordingly.
Link sharing etc would be appropriate once a relationship has been formalized.
J
@john_smith077 why isn't there an export?
Wait, there are DXF to SVG exports. I'll play around with them and see how they look.
PNG also has an alpha layer. This is a nice thing if you're layering your graphics. I know PNG is a newer standard but after testing, it was more expensive. I store a lot of photos of post product builds documenting problems, the good things and other things of interests. Then, I use a lot of images to bring existing stuff back into CAD that aren't in CAD. I guess I use a lot of images.
My testing came about because I'm using mongoDB (Rusty Shed) and a collective is limited to 6 meg. For some reason I wanted to load the most images I could in 6 meg but had no idea what that number would be. I have a web page that's close to 6 meg I used for the test and it's still alive today.
Pacific Sunsets
Ok it's only 5.2 meg but it's a lot of stuff. It's amazing because it loads on a phone quickly also.
I agree with you that you need to test your data and make sure it works for you. I would stay away from BMP images at all costs.
Here's the OS model:
Here's the vector version:
Here's the SVG:
click for cloud based SVG instance
-It isn't hard because you can export SVG from an OS drawing
-Does windows handle SVG? I have no idea
-To use SVG, you'll need an editor
-I've used SVG to make charts, it works great for that, you know which entity is picked, you can add labels
-It's freaking fast
I've downloaded a lot of drawings from the OS public space and created SVGs from all of them. They all look great and it seems like a great way to create a representation of a drawing in the cloud. I've posted many on them in the link above and they render really quickly. I haven't seen any errors.
If you're still on a desktop, you can download a svg to a local drive. From any desktop on a local network you can double click a svg file and it should open up in a browser and look great. Those you want to give a company access of engineering data should consider this approach as it doesn't require a login and can make your work company wide easily.
-google docs doesn't support svg, so that's out. (seems odd, SVG is a cloud standard and they should support it)
-word appears to allow you to cut'n paste them in but not add a live link to an svg file. (I don't have word and can't verify)
You can't have either of these document editors ask for an updated SVG from OS. You can have OS save a exported SVG when a drawing is updated to a location or they'll send you a link via email. It appears OS will cache the SVG for 3 days. To make this work, you'd have to setup a an email client and capture the svg location by scanning emails sent from OS. You might be able to hack this address and access the svg directly (https://cad.onshape.com/exportedData/62c5cfc8f5d890255670bc99?protected=true) but you don't know the address they create without scraping the email. I haven't found where they save the svg.
It might be best to cache your own svg files.
If you really want this to work automatically, I'd just build a webpage and use a browser.
Is this hard?
Not really, here's the url call for an svg download:
I'd build this on a back-end server and supply any company drawings to whom-ever could be authenticated. You could build an automated drawing server with svg using a browser fairly easily requiring no maintenance. GCP's document is amazing these days and they think anyone can build a server instance that'll scale. I'd start here.
If you wanted to build a manual system for google docs or word, you could do it with a little effort. Google docs has to support svg first. Windows needs to make it an updatable link. You can always double click the SVGs in named folders to display the drawings and leave updating word processing out of the equation. Roll-your-own document viewer.
