Top Down Design: How to create a new part defined by space between part and sub-assy
Hi, I'm new to Onshape and am trying to get a handle on top-down design in this platform. I have gone through most of the tutorials and have checked a number of forum posts, but haven't found the solution.
I am trying to create a new part based on the relationship between a single part, modeled in an in-document part studio, and an imported assembly.
I created a generic model to help me understand this process, which consists of a mounting plate and an imported motor assy mated to it at an angle.
.https://cad.onshape.com/documents/986342512d85a98829cada66/w/302f90979035a36830a30743/e/b588dcaca05d2add9546afdf?renderMode=0&uiState=62b4aadea7f5115a93dc2b6a
What is the best way to go about creating a new part to act as a mounting feature to join the two?
dirk_van_der_vaart Member Posts: 554 ✭✭✭
Not sure you have seen this one
https://learn.onshape.com/courses/top-down-design-techniques-in-onshape
steve_shubin Member Posts: 1,113 ✭✭✭✭
https://cad.onshape.com/documents/c513dca58e83326ced502611/w/d7a2fd1fa3b3fdd1de1ca1a8/e/78a4de4ab69572a4bcf1ce80
