How can I fix this offset sketch?
johan_moua
Member Posts: 4 ✭
in Drawings
I'm trying to create an offset curve, but for some reason when I join the two right curves together, it breaks the sketch. I've already tried selecting all of the curves, but it won't let me select multiple chains.
what happens when you make the two end points coincident to the edge here:
I'm not sure all the challenges you might be having with getting the offsets to behave, but if it's really painful, it may be time to cheat in 3D.
Extrude a surface which copies the edges you want to offset, then offset the surface, and use the edges that it creates (or depending on what you originally needed to do with the sketch, you might use the surface for a split or thicken etc..).
For whatever reason, the algorithm that offsets sketches, especially if there are a lot of tangent curves or splines, is not so good. The offsetting algorithm for surfaces seems much more robust.
