Profil on a Spline
EugenEugen Member, pcbaevp Posts: 19 PRO
Hello guys and girls
I start the profil in an angle of 90° and want to finish it in an angle of maybe 0°. How to do this?
  • S1monS1mon Member Posts: 3,982 PRO
    Add sections to both ends, Loft with a path instead of Sweep.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited July 2022
    @Eugen
    https://cad.onshape.com/documents/7af57b44fe139792806a3e29/w/5db11394284e047d6b2cb2fb/e/43396c0ff3e8cde1a737b6aa
    This method uses loft
    It does NOT require any intermediary profiles
    This profile rotates 1/4 turn from end to end
    The twist happens all along the path at a constant rate of rotation from end to end
    The twist is built around the 3D Spiral FS
    Also, a shout out to @Evan_Reese for his Freeform Spline FS
    Never used it on anything before. Didn't bother reading anything
    Played with it for a few minutes and was able to pick it up -- because of the well designed interface !!
    Like the ability to insert and easily edit. Great tool.
    You want a twist of 1/4 revolution (90°)
    The 3D Spiral featurescript will only do whole number revolutions
    So I have to use a LEAD IN to chew up 3/4 of a revolution
    So the straight lead in needs to be 3 times longer than the freeform spline
    3 parts of straight line to 1 part of freeform spline
    Another way to say it is, for the one revolution of the spirals ------
    3/4 of the length needs to be in the straight line
    1/4 of the length needs to be in the freeform spline
    This means that there will only be 1/4 of a revolution left for the spirals by the time they get to the freeform spline
  • EvanReeseEvanReese Member, Mentor Posts: 2,825 PRO
    Aw shucks. Gee thanks mister!
