Only one edge per fillet?
ron_moreland
Member Posts: 90 ✭✭
I have a shape I'm trying to apply a fillets to 2 corners. One corner is fine, when I add the second corner, the fillet fails to generate. Is this normal behavior?
You should be able to use one fillet command to fillet hundreds of edges.
But you can't fillet an edge that is created by the same fillet comand. In those cases you need a second fillet feature
Makes no difference with tangent prop, radius, cross section type.
