Part Number generation and revisions for different branches
S1mon
Member Posts: 3,745 PRO
I've created a branch of a document which just has a single part studio in it. One branch is one flavor of a design and the other branch is second one. Each should have its own part name, number and revision. It doesn't seem like this is a well supported use case.
Normally in Enterprise, the part number button will generate a new part number, but if the part already has a part number the button doesn't work. I can still manually enter a number, but I might accidentally enter a part number which is being used somewhere else. I'm fine if for other use cases, this button would normally want to be grayed out, so maybe there just needs to be a warning dialog.
If I change the part number in the release dialog, the revisions don't reset to 1 (in this case, we're using a 1, 2, 3.. revision scheme). If I enter a new part number in part properties first, then when I make a release, the revision number starts at 1. This seems inconsistent and weird.
With that cursor, I click and nothing happens. I can enter a new number manually.
I would much prefer that the button always works, and maybe if the number is already filled, there's a warning dialog which says something like "Do you want to overwrite the current part number?" Getting that cursor with the circle and the slash through it really made me think that I couldn't make a change at all.
