Ace Editor Short Cuts (including To Upper/Lower)?
S1mon
Member Posts: 4,039 PRO
I know that in general, the FeatureScript text editor is based on Ace. I also know that most of the keyboard commands work. However, some are overridden by standard Onshape things. In this case, I wanted to use the "to upper case" command (normally ctrl-U), but it triggers the contact support pop-up.
Is there an official list of editor commands? Does someone know if there's a way to trigger "to upper case"?
Side note: are enums all caps by convention? Is this written somewhere in the standard documentation?
NeilCooke
Moderator, Onshape Employees Posts: 5,979
I use them a lot so I did a list a while back https://forum.onshape.com/discussion/12424/feature-studio-keyboard-shortcuts
Enum values are in Caps but name is in Title case such as UIHint.ALWAYS_HIDDENSenior Director, Technical Services, EMEA2
You answered most of my questions, but didn’t cover “to uppercase”. Should I assume that this is just not available in Onshape?
