Ace Editor Short Cuts (including To Upper/Lower)?
S1monS1mon Member Posts: 3,774 PRO
edited July 2022 in FeatureScript
I know that in general, the FeatureScript text editor is based on Ace. I also know that most of the keyboard commands work. However, some are overridden by standard Onshape things. In this case, I wanted to use the "to upper case" command (normally ctrl-U), but it triggers the contact support pop-up.
Is there an official list of editor commands? Does someone know if there's a way to trigger "to upper case"?
Side note: are enums all caps by convention? Is this written somewhere in the standard documentation?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    I use them a lot so I did a list a while back https://forum.onshape.com/discussion/12424/feature-studio-keyboard-shortcuts
    Enum values are in Caps but name is in Title case such as UIHint.ALWAYS_HIDDEN
  • S1monS1mon Member Posts: 3,774 PRO
    Thanks @NeilCooke
    You answered most of my questions, but didn’t cover “to uppercase”. Should I assume that this is just not available in Onshape?
    Correct. I went through every Ace shortcut to see which ones work.
