Drive Variable Studio from Part Geometry
fred_burtt
Member Posts: 17 PRO
Hi,
I have what will be a recurring project that tiles a wall of various sizes with formed sheetmetal parts, and may or may not have differing windows and doors.
I am creating the "tile" layout on a sketch of the wall using lines extended from the window and door edges, then subdividing the remaining spaces.
As such, the resulting sizes vary quite a bit, and my plan is to use the dimensions of the resultant columns and rows as variables to drive the sizes of the "tiles" to match.
Is there any way to use sketch/part dimensions to drive a variable studio table?
@fred_burtt the feature Evan linked to can be used to drive variables in part studios, and there are other features out there that import variables from other part studios. I don't think there's a way to drive variable studios from a part studio like that, but you can achieve similar (even if more clunky) functionality.
I need to export them to a Variable Studio so that they can be applied globally.
@SethF: It sounds like the features to import variables might be the ticket for me, which have you used?
A clean solution to this would be very useful, since it would allow the use of a varying master sketch to drive any number of part studios.
The std derive doesn't handle variables, but SuperDerive did the trick, is exactly what I needed.
Thanks to all of you, problem solved and I understand OnShape much better.
I've requested this feature to be added as soon as it was released. Only time will tell if it happens
Here's a relevant forum post. It references the function you can use to get all the variables from a given context. The linked FS is probably a bit overkill for what you need, but pretty fly.
