Align views via Navigation Cube without zooming out.
When working on a sketch, I may occasionally 'look around the corner' to find a reference point or something. When I want to re-align my sketch (Front, Top,...), I use the Navigation Cube...but it always completely zooms out!
This is quite annoying when working on a detail. I always have to zoom in again. How can I align the view again without zooming out?
Axel_Kollmenter Member, pcbaevp Posts: 432 PRO
You can select the face you want to look at and press "N". The Part will show you the normal view on this face and wont zoom out.By hitting "N" again, it shows you the exact opposite site of your selected view.Best regards,
Axel Kollmenter1 -
NeilCooke Moderator, Onshape Employees Posts: 5,891
Plus you don’t have to select a face, just hover over it.Senior Director, Technical Services, EMEA2 -
S1mon Member Posts: 3,499 PRO
Shift 1-7 are super useful hotkeys. I almost never touch the cube to orient the view.Simon Gatrall | Staff Mechanical Engineer | Carbon, Inc.
1
Axel Kollmenter
Axel Kollmenter
The shift 1-7 still zoom out. And also, I prefer the Blender navigation shortcuts, which uses the numeric keypad to quickly orient the views, and with only *one* key, not a combination.
