Align views via Navigation Cube without zooming out.
erik_bongers
Member Posts: 16 ✭✭
When working on a sketch, I may occasionally 'look around the corner' to find a reference point or something. When I want to re-align my sketch (Front, Top,...), I use the Navigation Cube...but it always completely zooms out!
This is quite annoying when working on a detail. I always have to zoom in again. How can I align the view again without zooming out?
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
You can select the face you want to look at and press "N". The Part will show you the normal view on this face and wont zoom out.By hitting "N" again, it shows you the exact opposite site of your selected view.Best regards,
Axel Kollmenter1 -
NeilCooke
Moderator, Onshape Employees Posts: 5,979
Plus you don’t have to select a face, just hover over it.Senior Director, Technical Services, EMEA2
Axel Kollmenter
Axel Kollmenter
The shift 1-7 still zoom out. And also, I prefer the Blender navigation shortcuts, which uses the numeric keypad to quickly orient the views, and with only *one* key, not a combination.
