How can I recover select features deleted a long time ago?
Than_BoganThan_Bogan OS Professional Posts: 6 PRO
I understand how to restore an entire old version, but what if I've made tons of changes, including (correct) deletions, and then realize that a few of my deletions were incorrect and I'd like to bring them back.
I can't see any way to do this without the (still missing) selective merge feature.  That would allow me to make a branch back at the features I want, and then selectively merge them to the main branch.
But maybe there's a way to accomplish this specific goal in a more direct manner?  It's basically a cut-and-paste of some features from one branch to another, but I don't know of any way to do that either.  I have this feeling that I'm missing something obvious.  Or at least I hope I am!
  • EvanReeseEvanReese Member, Mentor Posts: 2,676 PRO
    I've requested the ability to cut/paste features, which would have several other applications besides this one. As you say, Onshape isn't yet really set up to easily support a partial merge or partial restore, but here's one approach that might work for you https://forum.onshape.com/discussion/15028/pro-tip-how-to-restore-a-deleted-tab-after-you-have-made-changes-without-losing-work
  • S1monS1mon Member Posts: 3,745 PRO
    I find having the two versions open side by side is sometimes all I need to see what I did in one version vs the other. You can step through the feature tree in each and compare and decide what you need to recreate, and what all the choices were.
    It’s not the same as being able to copy and paste a bunch of features, but it helps a lot compared with other CAD systems.
  • Than_BoganThan_Bogan OS Professional Posts: 6 PRO
    Both helpful!  Thanks!
