Creating a custom beam: Read-only "Beams Profile" tab
ehsan_moravveji
Member Posts: 8 ✭
Dear @NeilCooke
I have a question regarding adding a simple beam profile, which I cannot find from the pre-defined set.
I have created a simple sketch of a rectangular hollow 100x20x2 mm steal profile. Then, from the "FeatureScript Notices", I retrieve the following coordinates:
"units" : millimeter,
"entries" : { "koker 100x20x2" : { "sequence" : "LLLL-LLLL", "points" : [-50, 10, 50, 10, 50, -10, -50, -10, -50, 10, -48, 8, 48, 8, 48, -8, -48, -8, -48, 8] },
Result: Regeneration complete
Next step (following your webinar back in 2017) is to copy-paste this snippet into the "beams profile" tab.
However, I have hard time accessing this tab. At the bottom of my page, the part studio and assembly tabs are the only two tabs open.
Furthermore, when I right-click on the item and choose "Open Linked Document", I certainly arrive at the "FeatureScript Beams Profile", but that is read-only.
My question is: how to access the beams profile tab (in writeable mode) to add my simple beam design to the drop-down menu?
Kindest regards
Ehsan
Kindest regards
Ehsan
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Hi @ehsan_moravveji - you should now be using the Frame feature which can be found in the Part Studio toolbar. This will use a sketch rather than the cryptic code I created back in 2016
The reason you cannot edit the original beams document is because you need to make your own copy of it first, that's why using Frame is much better.Senior Director, Technical Services, EMEA1
Perhaps it's time to update this page:
https://www.onshape.com/en/features/custom-features
I will start digging in.
Kind regards
Ehsan
