Creating a custom beam: Read-only "Beams Profile" tab
Dear @NeilCooke
I have a question regarding adding a simple beam profile, which I cannot find from the pre-defined set.
I have created a simple sketch of a rectangular hollow 100x20x2 mm steal profile. Then, from the "FeatureScript Notices", I retrieve the following coordinates:
"units" : millimeter,
"entries" : { "koker 100x20x2" : { "sequence" : "LLLL-LLLL", "points" : [-50, 10, 50, 10, 50, -10, -50, -10, -50, 10, -48, 8, 48, 8, 48, -8, -48, -8, -48, 8] },
 Result: Regeneration complete
Next step (following your webinar back in 2017) is to copy-paste this snippet into the "beams profile" tab.
However, I have hard time accessing this tab. At the bottom of my page, the part studio and assembly tabs are the only two tabs open.
Furthermore, when I right-click on the item and choose "Open Linked Document", I certainly arrive at the "FeatureScript Beams Profile", but that is read-only.
My question is: how to access the beams profile tab (in writeable mode) to add my simple beam design to the drop-down menu?
Kindest regards
Ehsan
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Hi @ehsan_moravveji - you should now be using the Frame feature which can be found in the Part Studio toolbar. This will use a sketch rather than the cryptic code I created back in 2016 :smiley:
    The reason you cannot edit the original beams document is because you need to make your own copy of it first, that's why using Frame is much better.
  • S1monS1mon Member Posts: 4,078 PRO
    @NeilCooke
    Perhaps it's time to update this page:
    https://www.onshape.com/en/features/custom-features
  • ehsan_moravvejiehsan_moravveji Member Posts: 8
    Thanks a lot @NeilCooke for your swift reaction. As a matter of fact, I was unaware of the Frame feature; still a newbie.
    I will start digging in.
    Kind regards
    Ehsan
