I cant figure out how to import a part into design studio....I dont want an assembly
tim_ocallaghan
Member Posts: 7 ✭
I'm in part studio and i want to import another part created (below) into part studio so I can work on both...I don't want an assembly as I can't do the same things....HOW do I import that 2nd part
matthew_stacy
Member Posts: 489 PRO
@tim_ocallaghan, "Derived Part" is the tool that you are looking for. And then use the "Transform" tool, if needed to correctly position the derived part.1 -
eric_pesty
Member, pcbaevp Posts: 2,475 PRO
You really should consider going through the "Onshape fundamentals" training...tim_ocallaghan said:thanks so much I would NEVER have figured that out....
You'll learn all about this and lots more and will get a lot more out of Onshape, well worth the time as you will be able to do things a lot faster after that.4
