Edit in Context
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
How can I jump back to "edit in Context" after I taped into an other partstudio/assembly/...? Without adding the new part in the assembly and right click "edit in context". Is there an option?
Best regards,
Axel Kollmenter
Axel Kollmenter
Axel Kollmenter
I liked how @NeilCooke saves the in-context reference in his cable-wire-routing tool with a featureScript function. The custom function generates an empty composite-part (that is excluded from the BOM, has no mass, etc) which, when added to an assembly, saves the context reference. If the context is lost, because no reference to the context was added, you can simply right-click the reference part and click edit in-context again.
I extracted the function that does just that here.
https://cad.onshape.com/documents/e0ff553d4d80306cb87a03ed/v/3e690a275f827f5c9f291c4f/e/899c7dd61072f7beab34140f?renderMode=0&uiState=62fbc690bfbba455b0954b1d
Axel Kollmenter
Axel Kollmenter
The featurescript creates an empty composite-part and mate connector which can be added to the assembly that the context was derived from. In the GIF you can see me create the in-context part-studio, add the reference featurescript and import it into the assembly. I also showed that by right-clicking the composite and pressing edit-in-context I could reopen the context that had been lost.
Hope this helps!
Axel Kollmenter
