3d sketch
Tom_3
Member Posts: 2 ✭
I'm new to onshape and I've been a solidworks user for 13 years, can you draw a 3d sketch in onshape?
3
Currently we do not have a '3d sketch' feature, but (as of pretty recently) we have ways of defining curves in 3d space. What is your specific use case for 3d sketching? Here are some of our new curve features:
https://cad.onshape.com/help/Content/projectedcurve.htm
https://cad.onshape.com/help/Content/bridgingcurve.htm
You can vote on this improvement request if your would like to see 3d sketching implemented in Onshape:
https://forum.onshape.com/discussion/comment/18866#Comment_18866
OwS
Ended up with a very small straight line and a pair of 2 point bridging curves to get to the desired result, but one multipoint spline with match tangency on each end would be very welcome.
Cheers, Owen S.
https://forum.onshape.com/discussion/6397/improvements-to-onshape-may-4th-2017
Awesome, you guys rock
Really like that you can set the start directions of multiple curves off one line, that's clever.
Did I mention that I'd like a feature whereby with the click of an icon Daisy Ridley brings a tray with a glass of scotch and 6 gold bars on it? If you could add that to the next update that'd be great.
Cheers,
I used to love 3d sketches(in solid works). I also hated how much I would feel frustrated by them when relations suddenly exploded into red for no reason. I wanted them when migrating into onshape but I absolutely do not miss them. It seems onshape has done a good job a maintaining a mode of operation where features are almost always able to reference edges straight off of existing geometry. I have found it to be more intuitive to create simply construction geometry and then directly use the edges from that geometry. Unless your using a 3d sketch to store a collection of edges that you convert off of existing geometry, in my experience, 3d sketches are sort of annoying to manage. And if your using them to store converted edges, in onshape, you can just directly use those edges or use a composite curve feature to basically create a 3d curve representation of a set of edges.
3d sketches are heavily used in surfacing for control sketches. I do not see Onshape's way of doing this. Yes, there are built in control lines, like solidworks, but much like solidworks, they do not suffice at times.
I'm not an expert in surfacing by any means, but the toolset is being expanded constantly. My understanding is that bridging curves and routing/control point curves, together with the "edit curve" feature are intended to replace what 3D sketches would be used for in surfacing workflows.
I've done complex surfacing for consumer and medical products for decades. I've used a lot of different CAD tools. I can definitely reproduce or do better work in Onshape than Solidworks. There are still things I wish I could do, and I would be happy if there were more generalized ways of manipulating curves in 3D, but with the tools we have now, you can do a lot. Short of complex Class-A workflows, or crazy parametric patterns (Alias, Rhino, Plasticity, etc territory) you can accomplish 95% of what you need in Onshape now.
