Stop Onshape appending "Drawing 1" to new drawings
M_Hellessey
Member Posts: 2 PRO
G'day Onshape experts!
I'm in the process of setting up my companies approvals workflow and standardising how we name parts, assemblies, and drawings. Something that is quite annoying is that when you make a drawing of a part / assembly by default it names the drawing the part / assemblies name and then appends "Drawing 1".
I understand that Onshape likely does this so that if a part / assembly gets multiple drawings they can be differentiated, but this isn't an issue for our naming scheme.
Is there a way to prevent Onshape from appending the "Drawing 1" to the tab?
emagdalenaC2i
Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
There are no option to change that right now.I agree with you, this sufix is no needed and usually force users to rename the tab. I would like if the tab just be named as the part/assembly without the "Drawing N" sufixUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común4
Lead Mechanical Engineer @ Healing Innovations
