Being able to access entities from other sketches when a drawing tool (line, circle, ..) is engaged.
alain_mazyalain_mazy Member Posts: 27
When creating new sketches, you cannot automatically join a segment located on another sketch, even if this one is visible as long as a tool is selected. to join two entities, it is necessary to disengage the current tool to then be able to use the constraints. That's a shame.
