Parts drawing not showing properly in assembly
vanya_evangeline
Member Posts: 4 ✭
in Drawings
I just recently started using OnShape, and I just created a part with a threaded hole using the helix tool, but when I imported the part in the assembly, the helix isn't showing on the hole, so it's no longer threaded. I wonder what the issue is here and how can I fix it? Thanks in advance
Also, is there a way to flip a part on the Part Studio tab rather than the assembly tab?
So if you would post the link or the URL to your document, that would be a good thing
But in the meantime —
The below document shows that threads can be brought from the part studio to assembly without any problem
The document below does use a custom featurescript. So you could install that if you want and make your threads in this manner
https://cad.onshape.com/documents/3deb43588ef7fa5f4a25e4d3/w/ba4cf11f62e5a6756888ce2e/e/41c81742bd79f85fbc3f3a9b
This is how it looks in the part studio:
But when it's imported into the assembly, it's not showing:
