Unable to use named views in Onshape drawings
Good morning fellow OS users,
I am having trouble using named views (Specific orientation with a section view) in a drawing. I am well aware of how I am supposed to do it since I did it in the past with a specific orientation only.
After creating the said named view, I try to select the orientation in the insert menu in drawing and the named view just doesn't show up..
So my question is: Should I be able to import a named view (Specific orientation with a section view) in a drawing or that feature is not developped yet?
Best regards
Best regards
Léonard de Vinci
Even if I refresh the drawing and the browser page, the named view doesn't show up.
I created a named view with a specific orientation and it does show up.
It makes me think it doesn't work because of the section view....
Have you guys tried to make a named view with a section view and successfully inserted it in a drawing ?
Can't wait to have answers to this problem...
n.b I tried it with an assembly and a PS
There is a problem with section view and named view.
Maybe you should ask for an IR on this
Léonard de Vinci
You wouldn't normally insert a section view directly (i.e. a view of the 3D model already cut) in a drawing as you would be missing "context" so I believe the omission of named section views from drawings in intentional.
You can however create a section view of an existing drawing view. In you case I would insert a top view of your workshop and then create sections showing what you want from there.
