Missing function Ground at orgin and Ground en root
I recently started designing things in Onshape. But i'am missing the function ground and root@orgin. This is a function I used a lot in Inventor to load models at the x.y.z coordinates as I drew them in my multibody. Can we look into adding this feature? This could be a solution for several people.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,884
    I had to Google this, so I guess it is a function only in Inventor? You can something similar by using a fasten mate and a mate connector on the part and the origin.
  • EvanReeseEvanReese Member, Mentor Posts: 2,503 ✭✭✭✭✭
    I still wish there were a "place at origin" option in the right click menu for parts, so I don't have to mate, then delete the mate for any parts that have been moved. I imagine it would just place them on the origin relative to where their part studio origin is.
  • eric_pestyeric_pesty Member Posts: 2,282 PRO
    edited September 2022
    Obviously this is the behavior you get when you first insert a part from a part studio without clicking in the graphics area but if you move it after, you can still get something pretty close if you first relocate the triad on your part and right click on it to "move to origin".
    This requires "something" to snap the triad to but presumably so does mating (unless you have a MC at the origin or your part)...
    As far as I know Onshape isn't even "aware" of where the origin of a part is within the assembly (although maybe it is and that's what it uses for the "group" contraint? Not sure....)
